need some info http://machopowerwagon.com/phpBB3/viewtopic.php?f=10&t=1721 |
Author: | Boone [ Mon Apr 16, 2012 9:48 am ] |
Post subject: | need some info |
just bought a 76 Ramcharger se 360 4spd guage package and tach,355 sure grip some one up dated the axles,and also put in manuel hubs,the truck still has the original transfer case 4 hi 4low 2hi 2low,will it harm any thing leaving this way or should i update the transfer case thanks,how do you down lode pics on here |
Author: | macho4x4warlock [ Mon Apr 16, 2012 7:36 pm ] |
Post subject: | Re: need some info |
Sounds to me like someone already updated the Transfer Case. The front drive lock out hubs are not original to the '76 RC. So..... looks like someone put a kit into the TC. You should be able to drive in High Range in two wheel drive with that set up. For four wheel drive, lock the hubs and use High Lock on the shifter. Same for low range 4X4, use LOW Lock on the TC. |
