It is currently Thu Sep 18, 2025 7:21 am
 Post subject: Floor Pans
PostPosted: Fri Jan 16, 2009 9:52 pm
I'm about to undertake replacing rusted floor pans in my macho. Have never done this before so any technical advice would be appreciated. The driver side is bad, the passenger side not too bad. I found some replacements online for around 30-40 bucks. Will post some pics on progress as I go. Thanks.
 Post subject: Re: Floor Pans
PostPosted: Sat Jan 17, 2009 2:16 am
I need to do the same thing on a couple of my PALOMINO W150's too....
who did you get the pans from????
only advice I can give is make sure you get a spot weld drill bit and drill out the spot welds for the pans.....and give yourself some time to do them...
I haven't done any, but seen a set done once before.....
PostPosted: Sat Jan 17, 2009 1:20 pm
Here is the link for body replacement parts...
http://www.rustrepair.com/
just use the search...
PostPosted: Thu Jan 29, 2009 11:07 pm
I need to replace some of my floor pans to.Please let us know how they fit.
