It is currently Thu Sep 18, 2025 12:17 pm
 Post subject: 8 3/4" rear end housing casting number
PostPosted: Fri Jan 22, 2010 7:51 pm
Howdy,
Does anyone know where the casting number is located or stamped on the 8 3/4" rearend housings? I can't find it! I know there's the casting on the carrier, but trying to figure out what it's out of, has spring perches on top, factory welded shock mounts on the front side of the axle tubes, 2.94 gear, 489 case, 55" wide from brake flange to flange. Any ideas?
Thanks for the help!
-Jimbo
