Finally waited long enough, ordered and installed one of those Hellwig rear sway bars that Sam told me about. Installed on a '92 W250 Cummins. Easy install, 1 1/2hr-2hrs. No drilling. About the same diameter as the front, 1 1/8" dia. We'll see how it works out this week! Would most likely work on the 1/2tons also, IF you have a front one on there too. Take a look. And if you had a lift, I think you could extend the end links. Bigger than those ones I see on the new factory Phords..
Attachments: |
