It is currently Wed Sep 17, 2025 11:01 pm
 Post subject: 77 Dodge W400 360 rebuild.
PostPosted: Sat May 21, 2011 4:08 pm
Hello, I'm working on my W400 and would like some recommedations for it's 360 engine. The truck has a 435 trans, 203 transfer case, dana 60 front and 70 rear w/ 4.99 gears. Currently the truck is stock with about 21,000 miles (and who knows how many hours of idling) and I would like to replace the cam and carb to get more power. What would you recommend for this truck. Any machine work that I should have done?
'08 2500 QC, LB, 6.7L, 6spd Auto, 4x4
'01 1500 QC, SB, 5.9L, Auto, 4x4
'79 W150 LB, 360, 727, 4x4
'77 W100 Stepside, 318, NP435, 4x4
'77 W400 Chassis, 360, NP445, 4x4
'70 W200 CrewCab, SB, 318, NP435, 4x4
'61 D300 Dump Bed, /6, NP445
 Post subject: Re: 77 Dodge W400 360 rebuild.
PostPosted: Sat May 21, 2011 4:21 pm
Here is a picture of the truck.
PostPosted: Sun May 22, 2011 1:35 am
first off....NICE W400!!
do you have to worry about emissions there?
If not, I would go with a mild setup myself....
1968-9 340 hp manual camshaft...late model swirl port 360 heads-or-360 "J" heads...aluminum single plane intake....4bbl edelbrock carb...headers with 2 1/2 - 3" collector and some good dual exhaust.....also make sure the vacuum advance is working on the dist, and add light advance springs to the weights...
If your going to build it, I would also bump up the compression a bit, maybe 9.5-to-1 or so...
PostPosted: Mon May 23, 2011 12:11 am
Thanks. No worries about emissions here, anything older than 1980 is exempt. I'm putting a dump bed on this truck for hauling gravel, dirt, and such around the house. I'm wondering why a single plane intake? I've always had dual planes on my trucks and have never played with a single before. What advantage would it give?
Thanks, Scott
