It is currently Thu Apr 25, 2024 1:01 am
 Post subject: Wanted 4X4 Turbine wheel center cap
PostPosted: Tue May 30, 2017 6:36 pm
I'm looking for one turbine wheel center cap for my 83 Dodge Power Ram Prospector. Part number 4164411 Used is OK and as long as it has at least one mounting point intact I can usually mount it with longer screws. I can use either a wheel cap with the center open for the front axle or a cap with the closed end for the rear. I have an extra end cap. It was all that was left intact of my center cap when an unattentive cab driver spent more time looking at his I pad instead of where he was going. Luckily my 33 inch BFG absorbed most of the impact. I know these are hard to find but I will take most any condition part. My other 3 caps are no beauty queens. Thanks for your consideration.
 Post subject: Re: Wanted 4X4 Turbine wheel center cap
PostPosted: Tue Dec 31, 2019 2:46 pm
Finally found a couple, and a factory Ramcharger roll bar.
