Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Macho Leaf Springs
PostPosted: Fri Jul 29, 2011 9:49 am
Yes they do..............
http://www.sdtrucksprings.com/index.php ... x=104&y=12
PostPosted: Fri Jul 29, 2011 7:15 pm
dodgeguy wrote:
Will this fit my W150?
http://www.sdtrucksprings.com/index.php ... ts_id=7421
They dont have rear springs though.
yes, those are the fronts.....and yes they have the rear springs too
PostPosted: Mon Aug 01, 2011 6:01 pm
So which rear springs will it be?
These? http://www.sdtrucksprings.com/index.php ... ts_id=7565
Or these? http://www.sdtrucksprings.com/index.php ... ts_id=1480
Or these? http://www.sdtrucksprings.com/index.php ... ts_id=1478
P.S. Im looking for as close to original as possible.
PostPosted: Sat Sep 24, 2011 9:51 pm
Thank you for your help. I found all the springs for my truck, but was wondering if putting on these springs will affect my GVWR? I know Macho's had higher GVWRs of 6100 lbs. Will adding these springs decrease that.
PostPosted: Sun Sep 25, 2011 12:41 am
the top one is the most common on a W150 truck...1650 spring package, but one could have probably gotten a stiffer spring too...
PostPosted: Sun Sep 25, 2011 10:09 pm
The leafs you pointed out were for a d150, but will that still work for my w150? Also, my GVWR is 6100 lbs, GAWR front is 3260, and GAWR rear is 3500.
PostPosted: Mon Sep 26, 2011 12:02 am
the difference between D series and W series springs back then on a 150 was if it had a block in it for the 4x4, and which spring package it had. most all that I have seen an underhood label on said 1650 rear springs....
PostPosted: Tue Sep 27, 2011 7:28 pm
I'm thinking about going with a rough country 4 inch lift, but was wondering if my 31'' tires will look good with that. I dont want to change tires because they're brand new. Will it look good or bad? thanks.
PostPosted: Tue Sep 27, 2011 9:13 pm
it will have some space there in the wheel wells with that size.
PostPosted: Sat Oct 01, 2011 11:27 pm
I'm sorry if this is annoying, but even though in the description in the add a leaf kit, where it says drivewheel is 2wd, it will still fit my 4wd?
