Well here it is my Frankenstein creation! I bought this truck on ebay, it's obviously not a real Macho, but a 1975 Dodge Power Wagon. Here is the ugly...
License plate area needs a light Driver's side turn signal and front marker are burnt out There are three brake lines which need replaced in the front of the truck The rear brake cables are also bad and the parking brake does not work The vehicle had a four inch lift, however the drive shafts were never prepped for the lift, so the front drive shaft is hanging out of the front dif. The rear axle of the vehicle needs realigned The body mounts on the vehicle are in upside down and two are missing in the front end The tie rod wasn't installed properly and the tie rod ends are shot The vehicle needs a front end alignment like you read about, alot of slack in the steering The truck needs axle seals The vehicle will require catalytic converters in order to pass PA's requirements The exhaust needs hangers The EGR Valve is disconnected The vehicle has no working horn The speedometer cable is inoperative The transmission has a leak possibly around the gasket area and was missing a bolt, I already replaced the exhaust manifold gaskets and tightened the collectors. The KC lights needs reinstalled as a result of shipping The vehicle has no working window washers or resovoir The vehicle begins to stall out when accelerating and The vehicle has a bed from a 1978 Dodge truck, a fender possibly from a 1978 Dodge truck, and I think that is about it. Goofing thing is I still love the truck and I think it will be great once I fix everything, but man what a list.
If anyone has any suggestions for my project other than setting it on fire and hope for the best please let me know. Thanks
Attachments: |
File comment: My Frankenstein
