It is currently Thu Sep 18, 2025 12:19 am
 Post subject: engine question
PostPosted: Tue Aug 31, 2010 1:59 pm
Ok new engine is here. It's been a long time since I've worked on these trucks. I know I'm going to make a few people upset cause I'm not leaving it stock but......sorry. anyway I'm removing the tired 318 and putting in a fresh 360 my question is which accessories won't interchange and I'm replacing the balancer will the converter also need to be replaced. And I have a 1968 318 in the shop with an aluminum intake. Will this fit the 78 360?
 Post subject: Re: engine question
PostPosted: Tue Aug 31, 2010 10:04 pm
lexusbratton,
Sounds like a good project. The 360 engine is externally balanced by a specially weighted TQ. You can use the 318 TQ if you purchase an aftermarket 360 weighted flex plate. Summit HP parts house has the flex plate for about $90. The '68 318 intake manifold will fit the '78 360 with no problems. Also the passinger side motor mount "bracket" on the 360 is a shortered version of the 318. If you use the 318 bracket the 360 motor the rubber mount will not line up to the frame MM bracket. My suggestion is to find another 360 engine (Pick&Pull type yard) and grab the engine MM brackets.
PostPosted: Tue Aug 31, 2010 10:12 pm
Thanks so much. You know back on the day when I was 17 I yanked out the 318 from my old macho and put in a 360 I forgot all about those motor mount brackets. I have a pair from a van that I think is what I used last time. Thanks for the heads up on the flex plate
PostPosted: Thu Sep 02, 2010 6:21 am
sorry but dont mean to butt in.when you say fresh 360,i hope you got the oilpan with it cause 318 and 360 oilpans are different.just a heads up.good luck with your build
PostPosted: Thu Sep 02, 2010 7:30 am
Nope. But I have a 360 pan in the shop thanks. When I swapped in a 360 into my old truck, it was a complete carb to pan used motor. This one is brand spanking new long block. Thanks again I'm driving the macho to work one last time today. Motor comes out tomorrow.
PostPosted: Fri Sep 03, 2010 3:06 pm
Ok motor is on the stand. Ended up getting a 360 tq converter and the trans is out getting a bench job tonight. Why the *#&% can I not find a balancer for a 360 nobody has a listing for one.
 Post subject: 360 Engine vibration balancer/dampner
PostPosted: Fri Sep 03, 2010 3:58 pm
I found this site. Site said you bolt on counter weights that come with the their product vibration balancer/dampner.
http://www.pawinc.com/PDF_Files/PAW_Catalog/Dampers.pdf
PostPosted: Fri Sep 03, 2010 9:22 pm
I think you are talking about the front harmonic balancer right?
Your Mopar dealer should have them @ Mopar Performance P5007301, @ $100
Summit racing has them also, same price/free shipping on the holiday too!
PostPosted: Fri Sep 03, 2010 11:13 pm
You guys are great. Thanks again. Ok here's a quick background about me because I feel like a goob asking some of these questions. I have been a master Lexus tech for the past 10 years. I'm used to going to a parts dept and getting anything I need. This is my first old truck build and want to do it right. I'm sure I'll have more questions and just want to thank everyone who's helping me. Oh and the seats are going out Tuesday and the paint guy is coming by as well for preliminary paint and body inspection. I'd post pics if I could figure out how.
PostPosted: Sat Sep 04, 2010 1:58 am
A Lexus tech? Well then these old Dodges should be a piece a cake! Unless your used to plugging them in to computer to figure out the problem! He he! Have fun with the project!
-J
Users browsing this forum: No registered users and 8 guests
