 Post subject: can some one measure the inner and outer diameter of stripe
PostPosted: Mon Oct 10, 2011 12:32 pm
I'm looking the measurement of the inner and outer diameter of the yellow pin stripe on a macho rim. I just sand blasted my only original macho rim, any help would be great. I plain on getting a set made up that are precut so I can just lay them on the top of the rim instead of trying to apply it by hand and make round. The ones I just did on my rims I'm not happy with.
Thanks!!
 Post subject: Re: can some one measure the inner and outer diameter of str
PostPosted: Mon Oct 10, 2011 9:19 pm
My 77' Macho rims yellow stripe measures 1/4" wide total.
PostPosted: Tue Oct 18, 2011 2:13 pm
True, they should be 1/4" wide. They were originally painted on from factory. Phoneix graphix sends stripes in there kit but they are straight lines (1/4") and near impossible to shape to the round wheel. I had a professional do mine for $25.00 per wheel and they came out super. you might look into it.
