It is currently Wed Sep 17, 2025 11:09 pm
 Post subject: where to get paint
PostPosted: Fri May 18, 2012 11:48 pm
where did you guys get your silver macho paint? and wats it called? is it silver metallic or silver cloud? if im gonan repaint my truck i want to use the right colors that includes non glare black
 Post subject: Re: where to get paint
PostPosted: Sat May 19, 2012 4:46 pm
What year?
PostPosted: Sat May 19, 2012 7:03 pm
78
PostPosted: Sun May 20, 2012 12:01 am
Does your truck have the core support tag?
DT code should be 1592 Light Silver poly
ppg 3016 brochure in 78 called it Light Silver Metallic
Naturally, confirm with your research and your paint store
They can also help you with mixing a black with some flattener
To achieve a Lo Glare.
The last silver truck I did, with out a clear coat to make it look
more correct. Won't last as long if it's outside much. But looked
right.
PostPosted: Sun May 20, 2012 12:20 pm
i want mine to last, and i do want the lo glare ill use flat black if need be but my truck is outside all the time cause i park it in the yard, so im sorry it might not look correct but ill have to clear it unless i can use another color thats really really close thats not a metallic, and did you do your own paint 440 or have a shop do it?
PostPosted: Mon May 21, 2012 12:42 am
Not smart enough to paint.
Smart enough to have somebody that know's what their doing do it.
I don't mean flat, rather they mix in flattener to get lo glare or
what some might call semi flat (or semi gloss)
If it's going to be outside then Base / Clear for sure. (on the silver part)
Can't wait to see it!
PostPosted: Mon May 21, 2012 2:32 am
yeah well youd see the spare bed done first before anything lol im just hunting up the paint right now, then buying the stripe kit, all while doing the body work as my truck has some pretty nasty holes in the bed and doors and my floors will be a major pain. but im not going for a 100 point resto i just want it to look good and im doing it myself :D i will try to get pics asap
