 Post subject: 1976 W200 Crewcab powerwagon
PostPosted: Tue Aug 02, 2011 3:12 pm
I picked this truck up from the San Angelo, TX area 10 years ago and had grand plans of a Cummins swap, but too many irons in the fire forces sale. I have the original under hood decal and build sheet if a person wanted to go back to like stock.
Rest assured I did not just throw this truck together, care and correctness were used to make sure the correct components were used to make this truck appear as close to stock as possible, save for the chrome valve covers ;D
The truck is an original W200 D-code 440 automatic truck, that was swapped out for a 318/4spd/203 with 3.55 geared D44 and 9.25 rear axle.
The 318 has 80K on it and runs excellent fires right up hot or cold and gets decent mileage courtesy of a newer Rochester 2V carb. The clutch has a little over 5K on it and does not slip. The transmission has a new bearing retainer on front and the transfer case has a new rear output seal. All three have been drained and refilled with new lube as per the FSM.
The truck runs awesome and will scoot down he road effortlessly and pull down decent mileage (14mpg) if you stay out of the pedal.
It has some light surface rust on the floors, but I treated it and covered with POR-15 about 10 years ago. There is some bubbling in the driver side bed side, but the rockers, cowl, roof and doors are solid! The frame has surface rust like any other kansas/oklahoma/texas truck that is 30+ years old.
Here is list of some of the upgrades/features
    Front axle has had new bearings, rotors, calipers and pads in the last year
    Rear axle has had new shoes and drums
    Every light works, even the cargo light!
    New carpet will be installed this week
    Updated all the harnesses to 1978-80 style
    Dual fuel tanks for long hauls(in cab and frame mounted)
    Half tread+ 33x12.5x15 Dominator radial A/T's on 15x8 Cragar soft 8's
    2 1/2" single exhaust with flowmaster 40 series
    New energy suspension polyurethane body and cab mounts
    Like new heavy duty chrome drop step rear bumper
    Gooseneck ball mount under bed
    newer Monroe heavy duty gas magnum shocks fronts and Monroe air shocks in rear
    Accell wires, new cap/rotor and plugs
    All new filters (air, fuel, oil)
    Newer Modine 3 core heavy duty radiator made in USA!
    Moroso aftermarket valve covers
    New master cylinder and brake booster 2yrs. ago
I know there are some things I have forgotten, but If you have any questions, PM me here or email at moparman68 [at] g.m.a.i.l dot com
Truck is located in Wichita, KS
Asking $3250
More pics here:
http://img708.imageshack.us/slideshow/webplayer.php?id=1001912.jpg
