This truck has all the bells & whistles. On ebay, started today (I have no affilaition with the owner).
Here is the description:
This truck came from Washington state, I purchased the truck 6 months ago for my son, not what he had in mind. This truck runs great needs minor work like most 1976 trucks this is what I know about the truck. The motor is out of a 67 G.T.X It has: P.E.D built 440 1967 block. Bored out 452 Indy Heads new Elderbrock torque manifold new Avenger carb new built 727 transmission automatic 2200 stall speed convertor stock transfer case motor and transmission have less then 500 miles on them Dana 60 in rear and Dana 44 chevy conversion in front both have 488 gears new Posi-Traction front and back Detroit lockers rear drive line extended new leafs, shocks new suspension lift 6 inches Body lift 3 inches all new, done right new pan less wire harness installed right tilt steering column new B&M shifter new summit gauges new electric windows new leather summit seat new rear slider and glass new stereo wired with blaupunk can not find the face speakers pioneer new K.C lights new Steps 4 inch drop CAAR new carpet new tires 35 super swamper about 500 miles on them still 95% tread THINGS THE TRUCK NEEDS exhaust passenger side window not hooked up correctly all new just not hooked up right. not electrical, mechanical. minor rust on lower part of doors no where else on truck second tank spout was removed and welded, left a dent from heat. I have the spout, second tank is still in place. dash and doors were painted starting to peel.
http://cgi.ebay.com/ebaymotors/4X4-Pick ... 3efab13544 ...
or ebay auction; 270493889860
