It is currently Wed Sep 17, 2025 5:36 pm
 Post subject: Water in cab? Cab Lights? Dye floor mat?
PostPosted: Thu Jun 27, 2013 12:36 am
I get water in my 97 Laramie cab from a heater hole to the right of the safety restraint box. There is no discharge of water under the truck. There must be a vent pugged, how do I get to it?
I'm putting cab lights on ,like the looks of the factory type. What aftermarket have you used? Salvage lot, best?
I removed the carpet to replace w/ rubber covering, but I what do I use to paint the black rubber to get tan/camel/driftwood color
 Post subject: Re: Water in cab? Cab Lights? Dye floor mat?
PostPosted: Thu Jun 15, 2017 7:44 pm
Sometimes outside area at the bottom of the windshield will get debris in the drains and water will back up and leak into the cab below the dash
