What State are you trying to register? In California the weight certification label is not needed. The information is on your vin..... D13AP9S228921::: deciphers:
You entered the VIN Number: D13AP9S228921
D1 MODEL DESIGNATION D100 or D150 for 80
3 BODY TYPE Conventional Cab W/Utiline (Step Side Box)
A GVW CLASS 6000 lbs or less
P ENGINE TYPE 318-1
9 MODEL YEAR 1979
S ASSEMBLY PLANT Warren Plant No 1
228921 Sequential Serial Number .
In California, DMV will send you to a Weight Station for Laden Weight Slip. Then you will register your truck with that laden weight certificate.
