It is currently Wed Jun 18, 2025 8:39 am
 Post subject: no start maco
PostPosted: Wed Jun 12, 2013 12:26 am
I have a 79 maco that has sat for a couple . Turns over great no fire, possibly a faint ignite as I drop the key. I changed to my ballast resistor but no uck. Yes. I have primed the carb. Anydeas?? I have had this before a few years ago.Thank you
 Post subject: Re: no start maco
PostPosted: Wed Jun 12, 2013 1:28 pm
I have had that happen and it was my ECU box that was the issue. Have you checked to see if you any spark yet? Could also be your coil quit.
PostPosted: Fri Jun 14, 2013 1:55 am
had that happen...check your ECU, and as crazy as it sounds, find your dist plug, and un-plug it, then plug it back in...had to do that on 2 of my trucks this year for some reason...
PostPosted: Fri Jun 14, 2013 7:26 pm
Thanks, I'll see if I can squeeze in to try the remedies
PostPosted: Sun Jun 23, 2013 1:10 am
A big thank you Sam, the plug & unplug worked. Must corrode from sitting.
Now to get the carb touched id has always been c-o-l-d blooded
PostPosted: Sun Jun 23, 2013 11:13 am
anytime.... glad I could help..
