It is currently Thu Sep 18, 2025 3:43 am
 Post subject: would this be even worth saving?
PostPosted: Thu Jan 22, 2009 7:30 am
Would this even be worth saving. looks to be a little more work to get road worthy than i would be able to do. it is the only one close enough to me. i kind of like the color. i would rather have my yellow 400 or 440 macho. problem is i dont know if there will be anymore yellows for sale anytime soon. this would hold me over no problem. im just worried why the gas tank is not installed? what will be required to install the gas tank. did it rust off? parts missing? if so where do i get replacement parts.
here is the AD:
1978 Dodge Truck Power Wagon. Truck has a strong running 360 small block; Edelbrock intake; Edelbrock carb; Mickey Thompson valve covers; headers; Flowmasters; Direct Connection: upgraded ignition; short wheel base; 4 x 4; automatic. The truck needs a little work to complete. The gas tank needs to be re-installed. Runs great. Macho package. Comes with title. $1500. Call 571-330-8833.
 Post subject: Re: would this be even worth saving?
PostPosted: Thu Jan 22, 2009 10:51 am
that is a cool one....I would say YES
PostPosted: Thu Jan 22, 2009 11:32 am
what color is that?
PostPosted: Thu Jan 22, 2009 1:09 pm
I was looking at that truck back when I had my T7 69 bee, thought they would of looked nice together. He probably just took the tank out to clean out the bad gas from sitting and never put it back in. Shouldn't be to hard to put back in.
PostPosted: Thu Jan 22, 2009 1:50 pm
I like it but it isn't close to me so I would have to rent a truck and trailer it back. Looks like most of the pieces are there. 360 with headers so there should be some power. Making a run there and back would be too much $$$ for me otherwise I might consider it. ;)
PostPosted: Thu Jan 22, 2009 2:55 pm
i am in NY by buffalo so it is not that close to me either. i wish he would send me more pictures. still waiting.
PostPosted: Fri Jan 23, 2009 1:12 am
the color is "medium tan metalic"
PostPosted: Fri Jan 23, 2009 7:26 am
looks like it is copper.
thanks for the info.
PostPosted: Thu Jan 29, 2009 10:37 pm
It could be that the gas tank got a hole in it.My 78' has a plastic gas tank and it recnetly started leaking.It may have got a rock in between the strap and the tank and wore a hole in it.That truck has been for sale for quite awhile.I'd snatch it up if I was you.Of course I can't pass up a Macho if it's reasonably close to me. :mrgreen:
PostPosted: Mon Jul 05, 2010 1:44 pm
You should definitley snatch that up. It's runnig and looks great, what more can you ask for? Even though this post is old, is it still for sale, and where?
