It is currently Mon Jun 30, 2025 5:04 pm
 Post subject: DANA 44 bearings.
PostPosted: Thu Oct 22, 2009 9:44 pm
I went off-roading last week only to totally destroy driver side wheel bearings on the way home. When the bearings went, the spindle ate into the steering knuckle. I finally found a knuckle on ebay, but I can't for the life of me find an exploded view of which way the bearings go back in. Since everything came out in tiny fragments, I am not sure of how they go back in properly. I think there is an inner and an outer bearing. But if any one could chime in here I am listening. I do not have locking front hubs. BTW the truck did phenomenal in the mud, I think I had a bad seal and the mud and water washed the grease out. Any help or pics would be greatly appreciated.
 Post subject: Re: DANA 44 bearings.
PostPosted: Fri Oct 23, 2009 1:58 am
http://mopartruckparts.com/tech/t010.html
I hope this helps you out!!!!
PostPosted: Fri Oct 23, 2009 9:33 am
Thank you so much! That helps a ton, still can't believe that set up isn't on the internet more frequent. I figured it being a Dana it would be easily looked up online. Anyway I see the direction of the bearings now. You the man! :D :D :D
PostPosted: Fri Oct 23, 2009 8:15 pm
anytime! :)
PostPosted: Sat Oct 24, 2009 12:11 pm
Posting this info on here I found after days of searching and after palomino helped me out, in case anyone else runs into same probs.
http://ramchargercentral.com/index.php? ... ow%3Bid=35
PostPosted: Sat Oct 24, 2009 12:28 pm
that also looks like a good article....
