It is currently Thu Sep 18, 2025 3:45 am
 Post subject: Quick Question...
PostPosted: Fri Jul 02, 2010 9:09 pm
Since I can't find a box... Who makes short box, box sides? I need the whole flippin thing :x If none are available what the heck ya do to replace the thing? Sigh... all the freakin spot welds to drill.... oh, also who sells the box corners? where the tail light goes. Inner box sides? I'm imagining inner box sides aren't gonna happen. Basically only need the lip from the fender well to the outer side. Not real sure how to make that happen either. Front panel I have a perfect example to replace with but hafta remove from other truck. Ok, this wasn't a quick question. Mainly just need to know if the short box, box sides are available.
 Post subject: Re: Quick Question...
PostPosted: Fri Jul 02, 2010 9:52 pm
Here's a site for ya, I've gotten stuff through them..
http://cooltruckparts.com/
Otherwise I have a shortbox sitting here for ya, something to work with, a lot better than swapping sheetmetal.. I'm not going back to Wi until this Fall tho, it has a dent or two, rust just starting in the drivers wheelwell, inside box is so-so. Take a look..
PostPosted: Sat Jul 03, 2010 2:55 am
how much is said box? fall is soon enough.
PostPosted: Sat Jul 03, 2010 11:07 pm
You've got a PM..
