It is currently Thu Sep 18, 2025 3:29 am
 Post subject: 77 Macho knuckle
PostPosted: Sun Dec 26, 2010 1:06 am
I need the knuckle for the dana 44 passenger side. Wondering if anyone would have such thing laying around.
 Post subject: Re: 77 Macho knuckle
PostPosted: Mon Dec 27, 2010 12:12 am
I might have that...but I will have to look....
PostPosted: Tue Dec 28, 2010 11:12 pm
I have one, I would need 125 plus the ride for it.
PostPosted: Wed Dec 29, 2010 11:35 pm
Ok. The 3/4 ton knuckle is the same. I have one of them. Ok, now how do you get the friggin thing off.... got the ball joints loose, hub and rotor and bearing assembly out. The axle won't go through the spindle and the spindle wont go down far enough to exit the ball joints because the axle is in the way. What the heck? I'm not seeing the light apparently. Born a couple beers short of a six pack or something. But I'm truly stumped.
PostPosted: Wed Dec 29, 2010 11:36 pm
Only difference between the 1/2 ton axle and the 3/4 ton axle knuckle is the caliper mount. That has to be swapped.
