It is currently Wed Sep 17, 2025 11:04 pm
 Post subject: Front Spindle/Axle questions
PostPosted: Sat Dec 25, 2010 9:18 pm
Tore up my right front wheel bearing something royal. Wrecked the casting that appears to hold the bearing seal that bolts to the spindle. Pretty sure I wrecked the spindle, and outer stub shaft. Wrecked the hub. Trying to think what else I wrecked..... Anyways, short of finding another 1/2 ton truck which around here doesn't happen. I've got a donor 3/4 ton front axle from a W200 to steal from. Both are Dana 44's. What will swap out? What won't.
 Post subject: Re: Front Spindle/Axle questions
PostPosted: Sat Dec 25, 2010 9:50 pm
some stuff will, and some stuff wont. the stub shaft should work, the knuckle I believe is different, and of corse the rotor is different. The bearings and bearing retainer are the same though...I just went thru the bearing replacement and brakes on one of my trucks....
PostPosted: Sat Dec 25, 2010 11:36 pm
so I'm screwed on the knuckle... wonder how much work that's gonna be to find. sigh... hub is horrifically expensive.
PostPosted: Sun Dec 26, 2010 6:21 pm
If you have not had any luck finding the knuckle. Put a want on this site, it's very active for response:
http://ramchargercentral.com/wanted-or-trades/
PostPosted: Sun Dec 26, 2010 11:35 pm
Thank you sir. I'm gonna have to do that.
PostPosted: Fri Dec 31, 2010 10:21 pm
Or you can do like I did, get front and rear difs from a 85 Ramcharger. Lock out hubs, don't have to deal with the pressed bearings any more. You will need to get a wheel with the bigger bolt pattern though.
PostPosted: Sat Jan 01, 2011 12:19 pm
So going to he new style. How does that work. Leave the hubs unlocked and it would spin everyhing but the tire. Supposedly saving gas. Leave em locked all the time it would act just like it always did. Buddy of mine found me a front full time dif out of a 79 for 50 bucks. If it screws up agaian maybe I'll go that route. Rear end slobbers oil everywhere. So it wouldn't be bad to ditch it
PostPosted: Sun Jan 02, 2011 12:02 am
I think you'll have to keep those hubs locked in if you have the fulltime case if it's in Hi, otherwise you'll have to run HI LOC if you have the hubs unlocked, eitherway, your front driveshaft is gonna spin..
-jim
PostPosted: Thu Feb 16, 2012 12:00 am
try mopar truck parts they are great people and have a lot of parts
PostPosted: Thu Feb 16, 2012 4:01 pm
Great website too
www.mopartruckparts.com
