It is currently Wed Jun 18, 2025 3:35 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2, 3  Next
 Post subject: Macho Leaf Springs
PostPosted: Sun Jul 24, 2011 5:02 pm
Did Macho's have upgraded leaf springs? Also, I'm looking at an add a leaf lift, and was wondering if this will fit my 4 wheel drive truck even though the drivewheel says 2wd in the description? Please, any help would be appreciated, thanks.
http://www.streetsideauto.com/p/rancho-rs60012/
 Post subject: Re: Macho Leaf Springs
PostPosted: Tue Jul 26, 2011 10:49 am
Depends on what you are trying to accomplish.
......When I see this in an advertisement:
•Compensates for Slightly Worn Leaf Springs
•For Vehicles That Occasionally Take On Extra Load
....... I am wondering if the add a leaf is a waste of time and money.
I would get new springs.
Two more bolts on each side and your done with it (using heat & a cut off wheel).
PostPosted: Wed Jul 27, 2011 4:54 pm
some macho's had a beefier spring package on them, but most had the standard 3 leaf leafspring package, IIRC 1650 lb spring. The h/d spring was a 5 leaf unit, and was like 1900 lbs, and gave about 1-1 1/2 inch higher stance in front.
PostPosted: Wed Jul 27, 2011 5:07 pm
Where can I buy new leafs? Thanks.
PostPosted: Thu Jul 28, 2011 11:56 am
which ones?
PostPosted: Thu Jul 28, 2011 7:43 pm
Standard macho 3 leaf spring package.
PostPosted: Thu Jul 28, 2011 8:55 pm
Hey DodgeGuy, Is there a spring shop in your town? Most spring shops can put a main leaf in and rearch the other old old spring packs to your specs/wants. Draw Back: You have to remove spring and bring them into their business...... Other option: Bring the whole truck into them and tell them your wants. Expect a repair bill of over $500 on two rear springs. Then think about the front springs. The truck may have a large dump to the front (from age) with new /rearch spring in rear.
PostPosted: Thu Jul 28, 2011 11:52 pm
you might be supprised, mamopar might still have the ones for a 93...which would be the same spring rated springs
PostPosted: Thu Jul 28, 2011 11:54 pm
you might also try these guys
http://www.sdtrucksprings.com/index.php ... ts_id=9700
http://www.sdtrucksprings.com/index.php ... ts_id=7420
PostPosted: Fri Jul 29, 2011 12:48 am
Will this fit my W150?
http://www.sdtrucksprings.com/index.php ... ts_id=7421
They dont have rear springs though.
