WOW! Got alot of codes to look up............ The Sport Package had upgraded interior (high back seats &, carpet). The Sport fender emblems were on both front fenders and they used double sided sticky emblem tape to keep them on & mounted under the TrailDuster emblem. The TrailDuster emblem had the holes in the fender and the TD emblem studs are pushed through the fender holes using the studs with a very thin piece of clear tubing to help it snap into & onto the fender.......
A Sport Emblem was also on rear tailgate under the pot metal Plymouth TrailDuster Script...A Sport Emblem was on the dash under the sheet metal opening lid of the glove box between the AC Vents. The emblem had threaded studs that went through the sheetmetal of dash............
There should be a radiator core support metal tag that is mounted on top front near the battery side of support with two screws. That tag will also gives some interior options, exterior paint code, VIN and build order number (I found that 2/3s of the TrailDuster/Ramcharger metal tags are missing due to a body shop removal to get the colors for fender bender repairs).
Give me a couple of days to get your option codes.
Dave
